How to disconnect the client access the AR?
As i know, we can use the client-info function to record the details of all the clients being accessed, such as IP, user,ect..;
Is there any way to actively disconnect access to a client, check or cancel access in the form of a graphical interface?
Thanks all.
hello
You can use ArFirewall library
You can add// delete rules.
probably the way is to create a rule were you bock the communications from the IP & type of protocol that you want to bock and then link to the HMI.
Thank you,Marcos.
I will try it.
