How to add multiple states to the toggle button in the mappview. Eg, Separate boolean bit for ON command and separate boolean bit OFF command.
Hi!
Using a simple binding won’t give you this possibility, but I see two possibilities:
- Helper variable:
Bind a helper variable and realize the desired function in your functional code. - Event - action system:
Create an event action that is triggered by the state change of the toggle button and set your necessary variables depending if the switch is turned on or off.
Manfred
