OPC UA Automation Studio V6
I upgraded a Project from AS4.12 to AS6.0.2 and now I have a Problem with OPC UA.
The settings are the same as in the V4.12 Setup but if I enable any Security Policy, the CPU is set into Service Mode.
Thank you in advance.
Try upgrade to AS6.1 and all components to the latest one.
I updated to 6.1 but the CPU is still set to Service Mode.
You could try to disable Multicore support in AS OPC UA configuration in AS 6.1 (advanced visibility).
What cpu type is used ?
Hi!
i am using a X20EM0612 CPU.
Unfortunatly disablling multicore function did not fix my problem
OK… I found similar problem already reported and it is under investigation of development team. Functional workaround should be to remove safety TP. Please get in touch with your local office support. They will officially report your issue and provide you information about fix.
OK Thank you for your help!
I also have this exact same bug. I reported it to local Support today. They seem to be unaware of this bug. Disabling all security give other errors. “End point has none of the security policies enabled” And “Error creating server instance” and “Initialization of the Software Components Provider Failed”. The widgets in Visu just display XX.
