Hello, I’m trying to load backupfiles to an spare CPU model 7CP476.60-1, fortunatetly I could get backup files from a second machine with the same PLC, but now I’m trying to load the files in a spare PLC that faulted because of low battery, so using PVI transfer tools it seems that I need the OS V0235 in order to make the download, any help would be appreciate it
I’m not sure if AR V0235 was ever available as external upgrade, I found this version by chance just as a part of a very old installation package of AS2.5.0.x…
… so honestly spoken I’m not sure what you need in detail (the S file, or a BR file, or also the B&R libraries…)?
Nevertheless, I tried to extract everything belonging to “V0235 for PLC type CP476” I found, packed it into an ZIP and will send it as private message.
Thank you for your very fast reply ![]()
Just what I needed
