In a quite large project with mappView I get a page fault in the AsArLog library every time I open a watch window with large struture-PVs in it.
Is this effect known? Whats the story and even more important what is the solution to prevent this?
Hi @Michael_Hahni,
this is an issue that must be handled by official support. From a Community point of view, we can only give you general ideas:
if this does not help you, all this information should be provided to official support, they can help you to analyze.
Jaroslav
That issue known and will be fixed in the future with the next major version of Automation Runtime.
Afaik there is some buffer overflow happening.
For my project the one causing this issue is the LogArchInfo FUB
Thanks guys for the quick response.
At the moment we are using AR E4.92 on an APC3100. In the meantime I will check für the usage of the LogArchInfo FUB.
