Problem to show video stream from camera in mappView
Colleague @luoz tried to follow solution in this thread How do I get a video stream from my camera through mappview?
but has obviously some problem.
Original message:
hello! Which did you place the html?
I also has the error that the web connection denied
Hi @luoz, if you would like to get help from community you have to describe better what is your problem, how looks like your configuration, what test you have done, etc.
Hint: WebViewer widget is iFrame, so make sure that web server do not refuse this kind of connection. you can try it e.g. W3Schools Tryit Editor
we used the VLC plug-in to convert the video stream to a local INDEX file, and then deployed it in IIS
Hi @jayD, is this still an open topic? If so, can you please provide the full details on the problem you are observing, and the steps you have tried so far to solve it?
Got it, i already solved the problem .
@brittany.langston i will share the full steps within the catagory “Share Info&Ideas” after the holiday.
but i am not sure that Mr.Luo @luoz would see it.
@brittany.langston topic is here:video stream
