PVI instruction list batch file
hi all, is there a way to run a .pil file directly in windows.We are trying to speed up a process of transferring different configs to a plc .when you click a pic file it opens Runtime utility centre then you can execute the pil file.is there a way to directly execute the file with some batch command?
Hi there,
this help page should contain everything you need for that:
https://help.br-automation.com/#/en/6/automationnet/pvitransfer/operation/clparameters/automaticmode/pvitransfer_automaticmode_call.html
great ! thanks this solution works
