Hi @Rachel_M_Bond ,
We have few function blocks in the library AsIO that will help you:
- AsIOListDP and AsIOFListDP can be used to determine the existing I/O data points (for example: %QX.SS1.IF1.ST2.DigitalOutput02)
- AsIOPVInfo will tell which PV is linked with a data point.
We have an example in the Help of AsIO function usage
I see we have another post regarding AsIO library: How to use AsIO Library function AsIOFListDP() to get the pointer of a certain IO?
