Referencing the .eventscript files
just by referencing the files in the Config View of AS6.5, as I usually do, I found that the .eventscript file returns an error when it is referenced:
obrázok
When I click on it, it does not highlight the event script itself, but rather the content to which it is bound (all in the .vis file).
When the original event script file is added, it works as expected.
Are there any restrictions on referencing .eventscript files?
Thank you.
Regards
Hi @Michal_Malek ,
I don’t see any particular note of limitation in the latest AS help:
but in your care the error message is clear, there is a check for that.
I asked a product request for adding few notes for clarification.
Hi Valerio,
Do you have any updates regarding this issue?
Thank you.
Michal Malek
Hi @Michal_Malek ,
sorry for my late reply, but unfortunately, I don’t have yet an update from R&D.
I’m going to report to Support so they can create a CASE in our ticket system.
@Michal_Malek the topic is essentially answered, so referencing isn’t possible. Documenting it in the AS help request is just extra work @valerio.manenti is doing. Do you have any additional question? if not please mark respective reply as a solution. So topic is closed.
Hi Jaroslav,
I didn’t get the impression from Valerio’s responses that it isn’t possible.
Actually, at least it is possible to reference it:
obrázok
However, it cannot be compiled.
Please let me know if I’m wrong. If so, the issue can be closed.
Thank you.
Regards
Michal
Hi @Michal_Malek , I reported the issue to my local Support too.
I think there is a limitation but not documented so far, we will see the feedback from Support.
Hello.
Are there any plans on improving this in the future?
no feedback so far from R&D…you get from some departments super fast answer but in other cases you need to wait months…
I recommend to call our B&R office in your area and discuss your product request.
Just upgraded to MappView 6.6. This works now
Hi Stefan,
you are right, it works even though I did not find any remark in the revision info.
Michal Malek
