ACOPOStrak Designer 1.1 β Technical Overview and Use Cases
The latest release of ACOPOStrak Designer introduces several enhancements aimed at improving configuration efficiency, simulation clarity, and integration flexibility.
Key Use Cases and Benefits
OPC UA SmartComponent β Language Independence
Use Case: Integrating ACOPOStrak systems into multilingual environments without relying on English installations in RobotStudio.
Benefit:
Eliminates language dependency, enabling broader deployment across global teams.
Meets cybersecurity requirements for OPC UA connections.
Product State Visualization
Use Case: Simulating and monitoring the state of virtual products throughout the process flow.
Benefit:
Enhances understanding of workflows during simulation.
Enables visual debugging and validation of process logic via color-coded product states.
Visibility Groups
Use Case: Customizing the visibility of system components during design and simulation.
Benefit:
Simplifies layout views for specific tasks or presentations.
Reduces visual clutter, improving focus on relevant elements.
Labeling Enhancements
Use Case: Assigning clear labels to segments, tracks, and process stations for easier layout configuration.
Benefit:
Improves readability and maintainability of complex layouts.
Supports faster onboarding and collaboration across teams.
Streamlined Configuration Handling
Use Case: Directly modifying properties such as product states and movement limits from the property menu.
Benefit:
Reduces configuration time.
Enables intuitive setup without navigating multiple menus.
Automated Report Generation
Use Case: Creating a detailed PDF report of the layout, including BOM and technical data.
Benefit:
Facilitates documentation and review processes.
Provides a standardized output for internal and external stakeholders.
BOM.csv Export
Use Case: Exporting system data to a CSV file for copy-paste operations and external processing.
Benefit:
Enables quick data extraction for spreadsheets or ERP systems.
Avoids manual transcription from system data windows.
Predefined Colors for Process Stations
Use Case: Automatically assigning colors to station types for immediate visual differentiation.
Benefit:
Speeds up layout interpretation.
Allows customization while providing a useful default.
Color Coding Reference:
StopStation: Blue
ContinuousVelocityStation: Cyan
DecisionStation: Red
MultiStopStation: Green
Summary of Technical Advantages
Rapid project setup for ACOPOStrak systems using the Designer AddIn.
Efficient configuration and visualization within RobotStudio.
Seamless transition to Automation Studio for further development.
Enhanced simulation clarity through product state coloring and visibility control.
