Hi Alexander,
I can confirm that I’m also not able to redirect the -consoleOutput data to a file by the common way using ‘>’ (I tried different ways of redirection including starting a new cmd instance by calling cmd.exe /c “your command” and so on, but I also haven’t found a possibility - I haven’t tested anything with Python because already using batch files showed that behavior).
I’ve no idea what’s the reason behind, but it seems a bit like that the output is not delivered trough stdout or stderr, or that it can’t be redirected because of the output coding (for example as I know, UTF8 encoded data cannot be redirected on the console), but that’s just a guess.
I recommend to inform your local B&R support team about the behavior, so that they can check with RnD what’s the reason for and if the’re possibilities to realize your wanted functionality.
