When we set a T50 as NTP client to get time from CPU’s NTP server, shouldn’t it be one or multiple NTP client get time from one server?
Why do we need to have multiple server set in one client device?
You only need one, but there is the option to use multiple servers in case some are not reachable / offline for some reason.
It is not determined which is used as default, the one that is reached first and returns the “best time” (lowest stratum) will be preferred.
