USB Printer
The requirement is to use USB printer with C70 and C80, which library should I use and what can be the flow for the same ? Your replies will really help me.
in general a printer can be managed with the “AsUSB” library and this library also offers a sample
Please see the help of this library
You can enter this via the library samples within AS
The help also states which printer should be used and how the example works
Hello, I am using this Library Example, it prints but after the printing is finished, the paper is not getting out. Do you know what should I do? Is there an end page standard syntax or something like this? Thank you!
I don’t know the demo, but maybe you have to send the ASCII form feed character as I know, ASCII number 12).
Best regards.
This is the solution for my problem. Thank you Alexander!
