I have been having issues getting the debugger to work and get the following popup after activating it: “Debugger could not be started. Verify if the debugger has been activated in the configuration.”
That was the solution! I also found more information about it in the v6.7.13 Help in Programming-> Editors-> Configuration Editors-> Hardware Configuration-> CPU Configuration-> CPU Properties - System
