The project I’m working on was migrated from AS 4.12 to AS 6.5. The HMI seems to work fine when simulated in ARSim. for some reason I cannot see the Global PVs when trying to configure the WriterGroups in the PubSubConfig
thank you for the reply. The *.var files are in the root. The project uses the newest versions of OPC UA C/S and FX. unfortunatly the B&R Help could not help solve my Problem.
Earlier today I could select them and some time later they were not visible again.
Notably sometimes without changing a single thing in the project the behavior changed.
Then, I am not aware of such a behavior.
If there is no more suggestion/hints from other colleagues, I would recommend you to contact your local B&R office.
Have a nice time
