X20 AI 2322 Analog Input value not coming properly
I am Using C70 controller and AI Module X20 AI 2322. I am giving input to AI through NI module NI9472. when value given it to B&R module it is fluctuating value continuously changing,. Through my value coming from NI module is constant. What could be issue in this case? Is there wiring issue or grounding issue, or program issue?
the NI9472 is a digital output card from Emerson. The X20AI2322 is an analog input card for measuring currents between 0-20mA. Connecting a digital output to an analog input will not work. What is the purpose of this setup?
Regards
Hi @satyajitsinh2007
Do you still need help with this issue?
Due to inactivity closed.
