Acopos multi ncaction network init and reset
Hi there,
I am using ncaction(Netgl_Obj, ncNETWORK, ncINIT + ncRESET);
to reset the drive network if the drives have been powered down, but the PLC hasn’t
On one system with 7 drives it works fine and same with another with one drive, but on this one with 5 drives it doesn’t
I get error 32189 when the network has been interrupted then 29265 after running ncaction. I am using the sample code from the help and I have had it working on different systems, but this one has me stumped
Has anyone come across this before?
Thanks, Brian
I think the setting (Execute automatically after ACOPOS reset) can influence this behavior:
Thanks Corne, found it in the help:
I have this set to No in all three projects
Checked all other settings in NC configuration are the same too, but still can’t reset this one
Brian
