Hi Community,
for some weird reason AS Copilot is not working anymore for me. Whatever i write into the chat window i get this:
Using this AS-Code Version:
Thank you in advance.
BR Kenan
Hi Kenan,
have you checked if you have reached the user limit yet? You can find the button in the bottom right cornern where it says “AS Copilot”. If you click on it, you can see your used tokens:
Also your AS Code Version is outdated quite a bit (current is at 6.5.x), maybe this is also causing problems, as it is running fine on my end.
Thanks Julian,
i have upgraded now to the latest AS-version and everything seems fine.
BR
