For AS Code, the license is together with AS software, right?
I heard about for AS Copilot, there needs extra license, is it right? if it is, what is the procedure for licensing Copilot? For now I installed AS 6.5 I didn’t find anyway we need the license for Copilot is it because this is still a beta version? What is the license mode for Copilot?
I understand from the help (but I could be wrong) there is no special license for the AS Copilot, but it’s limited. A status of limits can be seen in the AS Code if you enable AS Copilot.
Hi @shenyang.zhou, I have modified your picture. There was a name of the author visible, which is against community guidelines. Data privacy must always be taken into consideration. Thanks, Jaroslav
Back to discussion, is there anyone who is using AS Code and knows what license is needed for Copilot?
