AS6 Library export
There is some way how to export library in AS6 as non-binary library? In AS4.12 are check box for export library as binary. When I clic to export library in AS6, there is only binary export.
I don’t know about AS6, just wanted to make sure you know you don’t neccessarily have to use the dialog? You can just copy the files from the explorer. Only difference when exporting I guess is, that the library will be in a subfolder “Vx.yy.z” (which you also could do manually…). If you already know: ignore me… :slight_smile:
agree with marcel, is this solution for you or you are looking for export wizard for any special reason?
@kovarj It’s also solution, but with a export wizard, it was a few clicks.
As far as I know this functionality will be added to one of the next version of AS6.
