AS6 Startup User Mapp View PopUp Login Failure
I added the template mappview provided by AS6 to my project.
I want to continue as Startup User Force Login under mapp view cfg.
I am failing in the login user section opened in the first stage on the MappView side.
What am I missing?
Pictures are attached.
Thanks.
Hi Arif,
I created a blank project, visualization, and user matching your settings. However, I’m not able to replicate your error. I would suggest re-typing the password in the User configuration to ensure that it actually is set as “1234”.
I’ve attached my test project in case it helps you.
VisTest.zip (46.5 KB)
Hello Marcus, I have one more qoestion.
I want to see all user always. But It permition just at admin role.
How can i adjust it.
Thanks.
I don’t think that is possible. User management functions (such as displaying the user list) are only available to users with Administrator roles (as configured in the MpUserX Configuration). This is documented in the Online Help.
