AsUSB library support for USB flash disks in Bergaplast PLCs
AsUSB library support for USB flash disks in PLCs
Problem Description:
  1. how large can support how large capacity of the USB flash drive, is there a limit?
  2. the latest version of the hardware and software version, whether it supports the commonly used exFAT, NTFS format of the U disk.
  3. USB flash drive use support hot swap? Will hot plugging and unplugging cause any damage to the PLC?
please see the help for the AsUSB library
Basically FAT12, 16 and 32 are supported. This Filesystems then also limit the size of the USB Sticks which (If I remember correctly) is 2 Terabyte for FAT32)
Also our PLCs do support hotswap but please note that writing to the stick and disconnecting it will cause damaged files or even a damaged file system on the stick.
