(Translation: Upgrades dialog cannot be opened. The service BrUpgrSrvAS6_DevCompiled was not found on the computer.)
The Windows background service does not seem to exist under this specific name (_DevCompiled).
Has anyone else encountered this bug in version 6.5.3.11? Is there a known workaround or a way to manually register the correct service without having to completely reinstall Automation Studio?
I have attached a screenshot of the error message.
this error is already known and our colleagues are working on it. As far as I know, it only happens in the German version of AS6.5.3. So probably using the English version will be a good workaround.
Hi Klaus,
also running the C:\Program Files (x86)\BRAutomation\AS6\bin-de\regobj.bat as administrator helped in my Case.
This might be a workaround until the problem is fixed.
Best regards Franziska
