B&R BRXTGR31 programming software
Dear engineers, does anyone have the programming software for this B&R text display? Could you please send me a copy? Thank you very much! My email address is w354317459@gmail.com.
the software was called ā€œSpecto-Sā€ and I will send you a private message where I will attach it.
Please note that I cannot give any help on this software as it is even too old for me (it was released in the 1990’s)
best regards
Oliver
Dear sir, thank you very much!
You are very welcome !
Hello dears, can you please send me this software? thanks!
Good morning, Oliver:
Would you be so kind as to send me the Espectro-S programming software so I can back up the six HMIs I have installed in my factory?
Thank you very much for your attention.
Dear Oliver,
Could you send me the Specto-S program? I also have a BRXTGR31 panel and unfortunately it’s not working. It seems like the communication parameters are incorrect. If I can fix them, it should work. My email address is: freelance.eng.group@gmail.com
I will send you a private message but please bear in mind that this software is 30 years old and we cannot give any help here
Received. Thank you.
you are very welcome !
Hello @oliver_D ,
I noticed that you have already sent the ā€˜Specto-S’ software to other members so that they can program or restore a B&R BRXTGR31.
Would it be possible to send it to me as well?
Thank you very much in advance and have a good evening!
Hello and welcome @KevinL
I will send you a private message containing the software
best regards
Oliver
Hi Oliver I wonder if you could help, i have a B&R BRXTGR31 HMI and im looking for Specto S software to program it. Do you know is this still availible. Thanks Ryan
Hi Ryan ! Welcome to the community :slight_smile:
Specto-S is still ā€œavailableā€ (which means I will send you a private message containing this software)
best regards
Oliver
@oliver_D Hello Oliver, I came across your reply about the Specto-S software for the BRXTGR31. I also repair saddle-stitching booklet machines and I’m running into the same issue with this device. Would you be able to share the Specto-S software with me as well? If a user manual is available too, I’d really appreciate it. You can reach me at sunghoon2323@gmail.com. Thank you so much for your help!
Hello @sunghoon2323
I have sent you a private message
best regards
Oliver
Hello, would i kindly be able to get the Specto-S software please.
Thomas.braisby@ferrero.com.
Thanks in advance.
Tom
Hello, do you have the Specto software of B&R Automation?
My email is: 4csmantemento10@gmail.com
Thanks sincerely
I also need the software for the BRXTGR31. My customer has a failing unit and and picked up a replacement somewhere. Thank you
Joby Williamson (joby.williamson@wba.systems note: no .com)
