Manuals for Specto_S
Since some of you seem to still use this old software package.
General information
The B&R MAESTRO's SPECTO_S (Semigraphic) software package displays process pictures and
data input / output in corresponding fields. Because of the B&R MAESTRO's multitasking capabilities,
several process pictures can be displayed simultaneously on separate terminals.
An editor is provided for process pictures and global text. Data for input and output fields comes
from a PLC CPU or from a B&R MAESTRO data range.
SPOS_D_2.PDF (1.5 MB)
SPOS_E_2.PDF (1.4 MB)
@christoph.hilchenbac Hello Christoph, I repair saddle-stitching booklet machines. There’s an issue with this B&R BRXTGR31 device, so I need the Specto_S software. I would really appreciate it if you could share it with me. If you also have the user manual, that would be great too. Thank you in advance!
Hi @sunghoon2323 ,
I saw that @oliver_D already sent you the software.
Unfortunately i didn’t find any documents containing ‘BRXTGR31’ :frowning:
I just found docs about some similar panels …
TER2_D_1.PDF (2.8 MB)
TERM_E_1.PDF (1.7 MB)
