we use the UnifiedAutomation .Net client to connect to the B&R X20CP0484 OPC UA server.
After updating of the client to version 4.1.0 it throws the exception “Mismatch of Endpoints returned by GetEndpoints and CreateSession” during the connection.
Were you able to find a solution to your problem, or are you still looking for one? If no one has any ideas here, I recommend you reach out to your local B&R support channel.
Hello!
I have the same problem today, after upgrading OPC UA from 4.0.3 to 4.3.1an you tell me, ist this workaround still the solution, do you have a quick recommendation, or should I reach out to the B&R support?
I would appreciate a short answer Thank you!
Since we are facing the same issue, it might be best to reach out to your contacts at B&R to see if they have an update. Hopefully, they can help us find a proper fix!
