Port conflict causing OPC UA failure
I have the same trouble. But even when I use your project xxx with the user and role, I got the same message when going to monitor mode. (Connection to OPC UA server not possible.
(For more details please refer to the help.)) I am desperate. I do not know what to try next.
I just posted on a different question but sounds like you have a similar issue and the OpcUa server is not enabled.
Please check
Thanks, Marcel,
just want to add this link:
No OPC UA connection to ARsim
Hello Christopher,
thanks for this link. The issue was as described in that link - the port 4840 was used by other process. I just changed it to 4841 and it works now.
