Hi everyone,
I have an issue on a PPC2200 with OS windows. After transfer my projet to the CPU the BR Hypervisor don’t want to boot… I don’t know how to solve this issues… Any help please?
Hi everyone,
We had same issue. The local support had no official solution, so I had to uninstall and then again install the Hypervisor…
But first, if you still didn’t do this, they advised me to create a CF image with the Runtime Utility Center and send it to your local support team. Then they can forward it to B&R development department. Last time I had this issue I had not time to do this so I’m not sure what exactly they can look up from the image.
From now on when I use Hypervisor, for big changes especially for global variables I do rebuild, transfer I use only for small changes.
Just add on to @Matic_Munda, make sure that you are using latest AR as well as latest hypervisor driver. Image before installation with clear description what you have done before this issue would help a lot with investigation.
