B&R Hypervisor setup error
Hi Everybody,
During the installation of B&R hypervisor on Windows appear the error message like in the picture attached below.
I follow the instruction of the help, i have already installed ADI drivers and replaced Intel SATA AHCI driver with Standard SATA AHCI driver and also checked the Windows registry .
I tryed to reinstall drivers but without fixing my problem.
Deos anyone have a suggestion for this issue?
You can find the procedure here:
AH || Installing standard AHCI serial ATA driver
I recommend checking the whole chapter regarding installation & configuration which you can find here:
AH || Installation & configuration B&R Hypervisor
Good luck!
Jan
Hi @mtwzinga
Were you able to solve your problem with Jan’s reply?
