Changing Powerlink node number at runtime on a Power Panel
I have a Power Panel (C80) and want to use the Powerlink interface as a Controlled Node and be able to set the Node Number at runtime.
I can see that there is a configuration called ‘Delay Node ID initialization’ that can be turned on, but I cannot see how to be able to change the Powerlink Node number.
This should be something you can do via the mapp IO system.
See mapp IO for details of how mapp IO works
You might also be able to do it using AsIoMMan (AsIOMMan)
I noticed that the links are not working.
Could the links be updated to the new AS-help website ?
Thanks for pointing that out! They are updated now.
