Concatenation of localized texts
Hello.
When adding a label in mappView, it’s possible to use a localized text, for example:
<Widget xsi:type="widgets.brease.Label" id="Label" top="10" left="10" width="220" height="60" zIndex="0" text="$IAT/EXAMPLE" />
However, I would like to display text that combines multiple localization IDs. Something like this is not accepted by mappView:
text="$IAT/EXAMPLE $IAT/ANOTHER"
Currently, as a workaround, I’m defining all required combinations in a separate .tmx file. While functional, this approach is quite cumbersome and difficult to maintain.
Is there a better way to dynamically concatenate multiple localized strings in mappView?
Thanks in advance for any suggestions!
Hi @Carl_Pracht
In label and textoutput it’s not possible, I know that in MappAlarmList you can display concatened localized text but because it’s defined in the config, I’m not sure that mappView do it.
I can take a look for MappView 6.X to have a recursive check for localized text in a custom label.
Florent.
Thanks for the quick response.
Hi @Carl_Pracht
There is a way to do this using snippet and text output.
You can define snippet and bind it to TextOutput like this.
Output:
Michal
This looks interesting. Thanks for sharing!
