Controlling sanyodenki/sanmotion OTC motor with B&R Acopos P3
Hi all,
I have a 4.7kW (28A, AC200V) motor from Sanyo Denki with Sanmotion sensor PA035 encoder. Is it possible to control this motor with B&R Acopos P3 and which model should I order for testing?
Here are some datasheets I’ve found about encoder.
Thank you for all information,
BR Tobias
Hello @Tobias_Zadravec
I am afraid that a “Sanmotion sensor” cannot be used with the servo drives from B&R.
Check following list of supported encoder types of the ACOPOS servo drive family.
https://www.br-automation.com/en/products/motion-control/additional-information/overview-of-encoder-systems-io-network-of-the-acopos-product-family/
Lukas
Hello @lukas.struber,
Have you found any data about this encoder, because I didn’t.
Then I will replace the motor with B&R one and this is going to work.
BR,
Tobias
unfortunately not really helpful information. That means we simply don’t know what this encoder is and which signals it has. So replacing it with a B&R motor is a good choice.
Lukas
