Hi B&R community! First time posting here ![]()
My team uses a X20CP1585s in our test panels. I update the code on them fairly frequency, direct transfer or offline transfers to other compact flash cards and then swapping cards on site. I’ve never had any issues with the CPUs booting until now. We have a new test panel, equipped with a CP1585, that I’m trying to set up but it seems like the CPU won’t boot.
The only LED status lights that come up are the CF (green) and DC (yellow/orange), according to the spec sheet CF just means the card is loaded and detected and DC means the power supply is ok. Neither R/E or S/E even blink. Every ~20ish seconds both the CF and DC LEDs turn off and then back on.
Any ideas what’s causing this or steps I can try to figure out what’s going on? I’ve re-flashed the card/tried a different card which didn’t help and I even tried a different CP1585 which is doing the exact same thing…
I’ve tried turning the dial into BOOT or DIAG mode and then turning on the CPU but got the exact same behavior
I haven’t had any success connecting via ethernet/automation studio either.
Let me know what I should try ![]()
Thanks folks!
