Quick question…
Is it possible to enable or disable hardware modules dynamically (at runtime), using the mapp IO library?
Like we do via physical view
Thanks in advance!
Hi Martin,
It seems that using the mapp IO library you can delete or add the hardware module by adding it in the xml file, but this file does not have a parameter to enable or disable the hardware module without deleting it. In this link you can see the structure of this import file:
Best Regards,
Eva
