Currently I’m still trying to figure out how to fix it manually… Maybe some of the B&R colleagues can check out the previous ticket?
Hopefully that gives a hint on whats causing this issue and how to workaround it manually…
glad you found the solution. What I am interested in, since I already started looking into reproducing it here, just for completeness: Which exact hardware module does your project have? P3DConfig is for dual axis, P3TConfig for triple axis, afaict.
Full name please, if possible
They’ve been with 5.24 too! I traced it back in and it seems that 2024 a dual P3 was replaced with a triple axis one, but the McAcoposTypeID did not change!
Versions at that time were:
AS: 4.11.6.26
mappMotion: 5.16.0 XT
So I don’t think there’s an issue in the current mappMotion versions… You could try to check if replacing a dual ACOPOS with a triple one in AS6 still leaves that parameter unchanged though…
