‘’ Name: “arrbtreeLookup” / Address: 0x00915760 / Param Count: 5 / Parameter: 0x0112b760, 0x00000005, 0x0a016040, 0x0c3d3a72, 0x0c4222ad’’
This is an error, how to troubleshoot using address mentioned above, and how to trace Name: “arrbtreeLookup”
Hi @subramanya.varanasi, welcome to the Community!
This looks like a message from the Backtrace of a Logger entry. Can you please share some more information about what issue you’re trying to diagnose and what lead you to this specific entry?
Usually the backtrace will have multiple entries because an error in a program may not be caught until a dependent function is called. Some of those entries will have green arrows next to them, meaning that you can double click on the entry and Automation Studio will show you the line in your code that it’s referring to. I’d recommend focusing on these to see if there’s anything that might explain the error.
