Error Regarding System ROM on B&R CP430 PLC During Program Download
I am experiencing an issue with a B&R CP430 PLC while trying to download a program using Automation Studio. The download process fails with an error message related to the system ROM on the PLC .
To investigate, I checked the available system memory through the Online > Info menu in Automation Studio. However, the information displayed about the memory capacity doesn’t match the expected values (screenshot attached).
Could anyone help me understand the possible reasons for this discrepancy? What could be causing the error, and how can I resolve it?
Thank you in advance for your assistance!
SG3 CPUs have an older flash technology. You can only delete the flash as a whole. If a download is carried out several times, the old areas are not deleted immediately, but only marked as ‘deleted’.
To delete the SYSROM, you must transfer the AR again. In contrast to the USRROM, there is no separate command to delete the SYSROM.
Regards
Dear @christoph.hilchenbac
I am a newbie in B&R automation products. Can you give me a hint how I should transfer the AR to the PLC?
which version of Automation Studio are you using ?
Automation Studio Version 4.1.14.40
then it should be this menu item:
B&R Online Help
Thanks! Christoph that saved me!
