Error while Registering/Sign Up to B&R Community
New users are not able to sign up, the registration page throws error “Recaptcha is required, but not configured”.
Hi @ranjith.rajachandran, thanks for letting me know, I will check it.
Hi @ranjith.rajachandran, can you confirm that registration works again?
Ther error with ReCAPTCHA seems to be solved, but still not able to register.
The registration is not working, below is the error shown when the signup button is pressed after entering the information.
should be fixed now. Can you confirm it?
@kovarj , It is not working. It’s just loading for some time and after some time page reloads.
The captcha is working now.
This is weird. I checked it with my private email, and it was working. Are you sure you used the correct password format? You should have received an error message if not. Is anyone else facing similar issue?
It is working now, for new email address signup works. For the email address with which we were trying to register was not working.
Then tried with forgot password and can login now!
thanks for feedback, I really appreciate your help :slight_smile:
