When using FBD in Automation Studio, connections where the signal flows backwards are prevented by the editor.
In this case, if I want to use FC3’s output as the input of FC1, is there a way to implement the demand in FBD?
You can cache the output on a variable (member) and use the same variable at the input.
Best regards, Stefan
