Get count of entries / used memory in MpAlarmXHistory
Hello everyone
I need to export the alarm history to a file which is then read/processed from our visualization.
To not miss any alarms I need to know when I have to export the history before the oldest value is overwritten. Is there a way to do that?
Hi @Jurg_Heiniger ,
Welcome to the community.
Theoretically you have all information on MpAlarmXHistoryUIAlarmList:
with PageUp/Down StepUp/Down you can navigate in all circular buffer and store the latest entry when you export the data.
Based on a timer/new alarm you trigger your search on the buffer, if that “latest entry“ is no more in the buffer you have found the condition to export again your data.
If you think: “Good, ready to implement that…” well be sure to test your implementation on real hw and monitor CPU usage with SDM.
Just an idea.
I do not think that someone can provide a better explanation of this topic than you. Thanks, @PatrickS
Thanks so much @PatrickS for sharing your smart idea + code + traces.
You already spent time on writing your answer, but I would like to ask you a favor, when you have time,: “Could you create a post for this topic on ‘Share info & Ideas’?“
Thanks again
Hi @Jurg_Heiniger , Could you mark the Patrick’s answer as a solution? Query feature was not ready at the beginning when R&D has released mapp Services,
they developed that as Patrick showed us for improving the performance on our system.
Thank you very much for your effort to show and explain your solution! This helps me a lot (not just a little).
I took content of @PatrickS reply and created new wiki post from it.
Thank you for the positive feedback!
@alexander.hefner also deserves a special mention here.
He came up with the idea, or rather gave us the idea, when he was still our contact at B&R months ago.
Thank you Alex, it works :wink:
Thank you very much, @PatrickS
It’s great to see you and your colleguages actively contributing in our Community, and giving very valuable feedback and help, together we’re strong!
My warmest greetings to you all!
