Enumeration have a 4 Byte Datatype and can directly used as DINT.
Does the following code match your requirement, it can also be used in Cyclic.
Use an Additional Integer Variable to which you Convert the Data.
VAR
TestINT : INT;
END_VAR
PROGRAM _INIT
TestINT := DINT_TO_INT(e_Offset);
END_PROGRAM
