Guide: Project Compare
  1. Introduction
  2. Offline Compare between two Projects
  3. Online Compare with Target
1. Introduction
If you want to compare two Projects you can use the Automation Studio Compare Source File Function. Right-Click to an element you want to compare and select a local compareable element.
I used this to make a code review between two Versions. In this way it was easy to have a fast overview about the Changes in an known environment.
Logical View
Configuration View
If you want to compare your current Project with the Files on the PLC you have to enable this option via this setting. For security reasons a Encryption is recomended.
thanks @michael.bertsch
