Thank you for using the community!
To keep discussions useful for everyone, please help us close the loop:
1. If you are asked for additional information, please provide it
Have you been asked for logs, error numbers, screenshots, or other details? Please share them as soon as possible.
If you need more time, that’s completely fine. Just let us know when we can expect an update so we know the discussion is still active.
2. If you received good suggestions but cannot test them right away
No problem. Just let us know how much time you need before you can try them.
Even if you’re not yet sure a reply contains the final solution, you can temporarily mark the most promising answer as the solution and update it later if needed.
Don’t worry, you can always return to the discussion, provide feedback, ask follow-up questions, or change the accepted solution.
3. If your question has been answered
Did you receive an answer that solved your problem or provided the information you needed?
Please mark the reply that helped you as the Solution.
If the solution was a combination of multiple replies or you solved the issue yourself, feel free to post a short summary of the outcome and mark that summary as the solution. This helps future users facing the same problem.
Why does this matter?
These simple actions help keep the community organized and prevent other members from spending time on issues that are already resolved or no longer active.
Most importantly, they make it easier for future users to find the answer they’re looking for.
Thank you for helping us build a better community!
Jaroslav Kovar ![]()
