Discourse introduced a new plugin—AI Helper—and I decided to enable it for our community as well.
With an AI helper, you can increase the quality of your questions and decrease the time you spend creating them. It is now enabled for testing, so let’s see what your feedback will be. I have created a short guide on how to make the most of it using a real topic from our community.
Think about your topic and try to describe it as clearly as possible. Do not forget to include all key facts.
As a first step, I will ask the AI helper to proof my description.
Note: Would you like to describe your issue in your native language? No problem use function translate to English instead . More info AI Helper plugin, part2
Check the suggestions and decide if the AI’s description has improved it. If so, use the confirm button.
Review the description again and adjust it manually if needed. The next step is to label your topic with tags.
Select all tags that relate to your topic. At least one is required.
As a final step, adjust your topic title. In our example, the topic was about PPC damage, but the question itself was about replacement. So we can use the AI version and modify it accordingly.
TIP: You can leave your topic title empty, and AI will still provide you with ideas based on your content.
And that’s it. Some notes from me:
The AI helper is an option you can use, but it is still AI and can change the meaning of your topic. Always verify and correct the output from it.
Let me know what you think about this plugin. Is there any other plugin or functionality you are missing in our community?
Jaroslav ![]()
