This is extension of AI Helper plugin introduction created and share here.
Here are two additional topics:
A. How to create topic in your native language and translate it to english?
Create new topic and explain your issue as best as you can in your native language
use AI Helper and its functionality translate to English
- verify text and press button confirm
- add tags and clear header as it is described here - AI Helper plugin - how to use it
B. How to ask AI to explain an unknown term?
If you come across any term that you are not familiar with, you can ask AI for an explanation. For example, see the term "IO-Link device
Select unknown term and use functionality Ask AI
Use option Explain
- AI will generate explanation for you, you can copy it to translator if need it
