HMI loses connection right after login in
I’m working on my first Mapp View project to build an HMI. When I deploy the project to ARSim, everything works perfectly. However, when I transfer it to my physical PLC (X90CP174.24-00), I can connect to the web interface, but after succesfully logging in, I immediately get a message saying the connection was lost.
I’ve tried troubleshooting but haven’t found a solution yet. Has anyone experienced this before or knows what might be causing it?
Thanks in advance!
Take a look into logger…I think there can be stored cause of your problem.
Hi there,
just as a heads-up: if you are currently using mappView 6.3.1 - this might be the culprit. In this case, upgrade to 6.3.2 or 6.4
Make sure the PLC time and date is correct
It was indeed the date&time that weren’t in sync….
Thanks for the help!
ok then it is cause by this.
