I want to learn the target modes on the servo.
I want to ensure that the servo in my hand searches for the sensor and accepts that region as 0 when it sees the sensor.
homing modes are described here
There is a decision making aid available right below there, which will lead you to either āAbsolute switchā or āSwitch gateā. Now you just have to look for the difference of those and decide which one applies. (Link)
Hope that helps
Hi @eem.ferhat, so what mode you have used? can you summarize your findings and close this topic?
Elbette sayın
Yaroslav Kovar
Limit anahtarı, mcHOMING_LIMIT_SWITCH
This topic was solved with this homing:
- Limit switch, mcHOMING_LIMIT_SWITCH
