Hi, I don’t understand how to set the date and time of my CPU. I tried by using the option Online→Info→date/time but it says I can’t and should look into the Help. I tried but didn’t find anything.
You can use the AsTime library. Or use the AsArCfg library to setup/configure NTP Servers.
If NTP time synchronization is enabled (CPU configuration), then you cannot set a time using Online → Info.
Sadly it it not active. This is what I see when I try to set it manually:
I will try with the AsTimeLibrary, although I was curious to understand why I cant manually.
If I look up “date and time” it says that my search give too many results, even when I deselect everything, so I can’t find any info.
Yes, I checked exactly that and it looks like yours
what version of AR/AS are you using?
Here are the versions:
AR: H4.9
AS: 4.10.5.38
Hi @Snide21 ,have you solved your topic, can you update us?
