sk9132132
(Sachin Kumar)
1
Hi Everyone,
I need support for getting this standard deviation value in decimal in production report.
The attached Process variable is Real, and I am using mpreportcore, mapp services configuration.
I am also attaching corresponding row configuration, Please Check.
You can set the desired precision for floating point values in the “Text Styles” configuration of MpReportCore.
Automation Help: mpReport Styles
And then when configuring your table you can choose which text style to use.
Automation Help: mpReport Tables
sk9132132
(Sachin Kumar)
3
Thanks for you reply, my issue has been resolved by changing in the same domain which you have mentioned.
