Importing CSV to TMX from script
Hi, is there a way to run tmx import with a script?
There is currently no way to automate the process other then perhaps generic UI automation tools. If there is a good use case then a product improvement could be started but currently I do not see much benefit in replacing the function with a command line based utility which would need to process the same parameters as the UI and check the target project for issues like open TMX files.
